09-10-2024 08:49 PM
What connector do we use to connect to Azure Data Lake. Would it be the same as Azure Blob Storage?
https://docs.workato.com/connectors/azure_blob_storage.html#create-your-workato-connection
What are the limitations when connecting to the Azure Data Lake? As Azure Data Lake has hierarchal aspect to it
Thursday
Follow-up
What connector do I use to connect to an Azure LogicApp API?
yesterday
Dear, @flo2024
Q: What connector do we use to connect to Azure Data Lake?
A: To connect to Azure Data Lake in Workato, you can indeed use the Azure Blob Storage connector, there are some limitations due to the hierarchical nature of Azure Data Lake Storage.
or you could use Workato’s HTTP Connector to interact directly with the Azure Data Lake Storage REST API, this allows you to fully utilize the hierarchical capabilities and other advanced features.
Q: What are the limitations when connecting to the Azure Data Lake?
A:
Q: What connector do I use to connect to an Azure Logic App API?
A: Use Workato's HTTP Connector to interact with Azure Logic Apps via their HTTP API. Configure the appropriate method (GET, POST, etc.), authentication, and body parameters to trigger Logic App workflows or retrieve data.
