06-27-2022 11:41 AM
Hi all, I'm testing the use of callable sub-recipes and I incurred in a limit on the size of the output. I t seams that the Json I'm returning gets truncated.
Here some more details on the Json:
1) it's speciefied with json schema in the sub-recipes trigger.
2) it contains a list of about 300 objects. Each object contains an integer and two strings.
3) the truncation looks like this:
"course_id": 1,
"type": "sometype",
"code": "MY0123co…(truncated here)"
"… (264 more truncated here)"
06-27-2022 11:53 AM
Hi Marcello, it's just representation of the json in the job. If you'd like to see the full return use 'Logger by Workato' application or send it to yourself using email.
