Compare two Json arrays to find the new and updated records
ankuragarawal
Hello Team,
I am new to Workato, i am trying to build a data integration to sync data from Workday to SharePoint List.
I have employee data coming from Workday, which is also stored in a SharePoint list. My requirement is to set up a daily integration that checks for new employees in Workday and adds them to the SharePoint list. Additionally, the integration should identify any changes to existing employee records and update the SharePoint list accordingly.
What is the recommended way to achieve it without using Foreach loop?
JSON1=[
"lastName": "Smith",
"User_Name": "jsmith1",
"Email_-_Work": "jsmith@example.com",
"Company": "TechCorp",
"Position": "Developer",
"Legal_Last_Name": "Smith",
"Employee_ID": "12345"
"User_Name": "jsmith2",
"Company": "TechCorp2",
"User_Name": "jsmith3",
JSON2=[
"Employee_ID": "12345",
"ID": "1"
"Company": "TechCorp3",
"ID": "2"
JSON1 is my main data source which should synced with SharePoint list, once we identify the changes, we can update/create in the SharePoint list, please note that SharePoint will have the extra column called "ID" which needs to be ignored when matching as this column is needed to update in SharePoint.
Any suggestions are highly appreciated.
Hi @ankuragarawal ,
Assumptions: with the above requirements, you able to fetch the records from both Workday and Share-point application.
Problem statement: You need a help in comparing two output response of both the application (Workday and Share-point)
Solution:  Pass the both the response as input to the Python component and where create two list
                     1. Create_list: To create new records in  Share-point
                    2. Update_list: To update the existing records in Share-point
Feel free to reach out if you need any further assistance.
Shivakumara A
5 REPLIES 5
blakesha
Both requests result in List datapills. Why not load them into two SQL Collections then just use SQL joins/queries with the two SQL collections to get the resulting List, then use that resulting List datapill to update/insert into the SharePoint list?
