Conditional outputs from a modal
jarh15
I have a modal where users can select multiple items. For only one of the items, selecting it triggers a second modal where the user must choose a subspecialty.
If the user selects that item, I want the final output to be a list of the user's selections in the first modal, but I want the subspecialty, to completely replacing the original item. For all other items that don’t require a subspecialty, the original selections should appear in the output as-is.
1dheeraj2
Hi @jarh15
Just to understand more:
  1. Regarding the subspecialty values:
    • Are these hardcoded, or
    • Are they dynamically fetched through a menu using an item ID?
  2. Understanding the Modal Relationship:
    • Is there a code-level relationship between the first and second modal values?
    • Or are they functioning independently?
Suggested Solutions:
  1. You can use the "View JSON" values in JSON parser to capture selected values from both modals
    • Python script approach (most efficient)
    • Alternative solution without Python (requires more tasks)
  2. If the modal values are hardcoded and independent:
    • Use variables after parsing JSON view data pill
    • Remove subspecialty entries using formulas
There are still several aspects we need to clarify:
  1. Output Requirements:
    • Do you need text values or backend values in the output?
    • Are your text and values identical?
  2. List of Values (LOV) Configuration:
    • What type of LOV are you using in both modals (static or dynamic)?
    • If static, we can leverage the parameter section
Please provide details about:
  • The architecture used to populate your modal LOVs
  • Your specific output requirements (text vs. value)
This information will help us suggest the most effective solution for your needs.
1 REPLY 1
1dheeraj2
Hi @jarh15
