Connector - Primary/Secondary
gordonhuworkato
Hello folks,
Does anyone face the limitation of primary/secondary connector (count = 2)
For example: if we have 3 or more slack workspaces, HTTP connections that we want to use in one recipe.
Primary/Secondary is good but we will need to remember which one is primary or secondary. I probably will not remember that ๐Ÿ˜…
Some vendors seem to allow arbitrary numbers of connections in one workflow. Having said that, it may make reading a recipe more difficult..
For example, I use one HTTP connector with different authentications headers as a work around. Callable recipes can be a work around too.
Thanks!
4 REPLIES 4
george4
Gordon Hu I faced that limitation while building sophisticated recipe that utilizes 3+ HTTP connectors to make calls to different APIs. Unfortunately, there is no workaround except dividing the recipe into smaller pieces and use Callable recipe for that.
georgiaria
It is also possible to rename your connectors to help you remember which is which. I name mine after the service, then the account. For example, when I create a new Google Sheets connection, it defaults to 'My second Google Sheets account', but I rename it to 'Google Sheets - myemail@mydomain.com' so show which account is being affected. ๐Ÿ™‚
mroldanvega
We have a naming convention that includes 'Secondary' for all secondary connectors, but in general this is a big limitation. Maybe Tridivesh Sarangi can forward this to the product team and see if there are any plans to remove this limitation.
tridivesh
Manuel Roldan-Vega Gordon Hu - thanks for sharing the feedback.
