10-11-2024 02:03 PM - edited 10-11-2024 02:10 PM
Hey all - I need to compose a CSV in Workato that I am not sure is possible, here is my criteria (screenshot below):
Row 1 has to be as follows: EmployeeManagerImport,,,,,,
Row 2 has to be as follows: H,EmployeeManager,EmployeeManager,EmployeeXRefCode,ManagerXRefCode,EffectiveStart,EffectiveEnd
Row 3 has to be as follows: D,EmployeeManager,EmployeeManager,{dataPillValue},{dataPillValue},{dataPillValue},{dataPillValue}
As you can imagine, row 1 is really where issues are being caused. Row 2 is effectively the header row, however I need the value in A1 and the subsequent blank cells in order to tell the system what action to perform.
Has anyone else run into a similar custom CSV formatting challenge like this?
#automation #hrTech #SFTP
10-11-2024 02:44 PM
Assuming you can make the CSV for rows 2 and onward without issue, all you need to do is add the header row -- like, literally "text add" the row to the beginning of the CSV.
"EmployeeManagerImport,,,,,,\n" + [CSV data pill]The "\n" is just a line break so it doesn't merge with row 2.
I just tested this and it works.
10-18-2024 12:51 PM
@gary1 Ah wonderful, this was exactly what I needed! This worked a charm, thank you. I have one related CSV puzzle I am working through that I was wondering if you had any insight on. I need my header row to remain static (XrefCode,EffectiveStart,Value,Employee_Id), that part is simple enough. However, I need the structure of the CSV to always have 4 rows, with the 4 values in Column A being static and the rest being dynamic. Sample desired CSV output attached below:
I took what you presented before, using a Logger Action, and pretty much tried to simply build the CSV from scratch (below). That said, I am presented with the fact that the formula has errors. I am not sure where I went wrong here... Let me know if anything jumps out at you!
10-11-2024 02:44 PM
10-18-2024 12:51 PM
10-21-2024 12:01 AM
Hi @spencerstone ,
I could see Concatenation operator is missing at the last row. Here I am providing the screenshot for the same.
Add "+" after the comma, it should work.  Please let me know if you need further information.
Shivakumara Avadhani
10-21-2024 08:49 AM
I was looking at it for so long that the commas and plus signs were floating!! Thanks for the sanity check
