Extract string from between two other strings
klandry
In a recipe, there is an error that is being returned in a datapill from an API call.
I want to extract just the error "text".
Here is a snippet of the string that is being returned:
,\"ErrorMessage\":\"Item KL65512 is not valid\",
I want to end up with:
I was looking at .scan, but I cannot seem to get the correct syntax to achieve what I am looking for.
Any help is appreciated.
Star Chef I
Star Chef I
This will work with the snippet provided, but without knowing the rest of the string I can't promise it will always work.
message.scan(/\"ErrorMessage\\\":\\\"(.*?)\\\",/)
I recommend parsing the API response instead, so this comes across as an actual data pill.
Star Chef I
Star Chef I
klandry
Thank you Gary. The snippet that I provided is unique in the string so I avoided posting the entire string.
I had gotten close to what you are suggesting and both seem to product the desired outcome.
.scan(/ErrorMessage\\\"\:\\\"([^\"]+)\\\"/)
The API response is available in the form of a datapill, but I could not find a way to get just that text without REGEX.
Thank You
