11-30-2023 10:33 PM
Hi
ISA*00* *00* *ZZ*TEST *ZZ*HOGAN *231129*1551*U*00401*000000001*0*P*>~GS*PO*MARY*HOG*20231129*1551*1*X*004010VICS~ST*850*0001~BEG*00*RL*823120**20231129~FOB*DF~ITD*05*2*****30~
I will receive one file and will have above line where length might be vary based on the file. I need to get value of "823120" and store it in a variable to use it later.
BEG*00*RL*823120 -- I would say 3rd argument of BEG segment.
Any formula I can use to get the value from a single line
Thanks in advance.
11-30-2023 10:50 PM
This finds the location of "BEG", slices off the rest of the string, splits the remainder into an array, and returns the 4th index.
Because "BEG" might appear elsewhere in the string, this one may be more reliable if the start of the "BEG" segment is always formatted as "~BEG*"
Here's the formula as text so you can copy/paste. Just replace both "x" variables with the data pill.
x.slice(x.index("~BEG*")..-1).split('*')[3]
12-03-2023 10:24 PM - edited 12-03-2023 10:25 PM
I don't think all of this could be done in a single line (at least not by me!), so I wrote a quick code snippet you can use in a Ruby action. It will output the following:
Here's the actual output:
Set up a Ruby action with one string input called "string", and pass in your string.
Set up the output like this:
Use this code:
string = input[:string]
begSegments = string.scan(/(~BEG\*\d{2}\*[A-Z]{2}\*\d+\*\*)/).flatten
begIds = []
begSegmentsFinal = []
updatedInput = ''
begSegments.each { | s |
begIds.push(s.split('*')[3])
begSegmentUpdated = s.include?('*RL*') ? s.gsub('*RL*','*RE*') : s
begSegmentsFinal.push(begSegmentUpdated)
updatedInput = string.gsub(s, begSegmentUpdated)
begIds: begIds,
# if you want a comma-delimited list, just use begIds.join(',') but you'll also have to update the output schema so begIds is a string and not an array
begSegmentsFinal: begSegmentsFinal,
updatedInput: updatedInput
It first uses a regex to find the BEG segments up to the ID value. Then it loops through the array of matches and uses gsub to replace RL/RE. In my opinion, this is a bit more selective/careful because it's only doing it on a portion of the BEG segment and not the entire input string where other instances of *RL* might exist, but I have no idea.
There are probably better or more efficient ways of doing this, but this should work until it doesn't!
12-03-2023 08:55 PM
Hi @gary1
Thanks for your quick reply 😊.
ISA*00* *00* *ZZ*TEST *ZZ*OTFWTESTUS *231201*2330*U*00401*000000003*0*P*>~GS*PO*TEST*OTFWTESTUS*20231201*2330*3*X*004010VICS~ST*850*0003~BEG*00*RE*823127**20231201~FOB*DF~ITD*05*2*****30~DTM*001*20231231~DTM*010*20231201~N1*ST*Georgetown*92*172002~N2*test, inc~N3*3059 M Street NW~N4*Washington*DC*20007~PO1*1*3*EA*20.90*WE*UP*816218025779*VC*5779~PO1*2*6*EA*20.90*WE*UP*816218026042*VC*6042~PO1*3*3*EA*19*WE*UP*816218028749*VC*8749~CTT*3~SE*15*0003~ST*850*0004~BEG*00*RE*823128**20231201~FOB*DF~ITD*05*2*****30~DTM*001*20231231~DTM*010*20231201~N1*ST*Georgetown*92*172002~N2*test, inc~N3*3059 M Street NW~N4*Washington*DC*20007~PO1*1*3*EA*20.90*WE*UP*816218025786*VC*5786~PO1*2*3*EA*20.90*WE*UP*816218026004*VC*6004~PO1*3*6*EA*20.90*WE*UP*816218026028*VC*6028~CTT*3~SE*15*0004~GE*2*3~IEA*1*000000003~
Above is the expected output result.
1st thing is Need to extract value of 823127 and 823128 from BEG segment and store it in a variable to use it later(concatenate would be fine. e.g 823127 | 823128 ). we may have mutiple BEG segment in a single line and length may vary between each BEG.
2nd thing is to update *RL* to *RE* in BEG segment. we can use gsub but do we have any other efficient way?
Use this code:
begIds = []
updatedInput = ''
begIds: begIds,
12-04-2023 02:40 AM
Thank you very much for your solution @gary1 . it worked perfectly for my scenario.
