Possible to format JSON in Logger or Email?
gsbrown
I have a recipe with an HTTP Request action with monitor error handling to logger and email.   I can attach the HTTP Response "Body" field into the logger and email,  but is there a way to apply JSON formatting to it so it's easier to read?
2 ACCEPTED SOLUTIONS
You can do this with a quick JavaScript action.
Create one with an input and output like this. Replace the message data pill with your HTTP response:
Use this code:
exports.main = async ({ obj }) => {
  var pretty = JSON.stringify(obj, null, "\t");
  return { pretty };
You can use the "pretty" output pill as-is in a plaintext email to get this:
If you want to use it in an HTML email, use "pre" like this:
Emails like this in monospace font:
Hope this helps!
gsbrown
It's working now,  thank you!
Realized,  from the "Send Request via HTTP" action I needed to pass through the "Response" datapill and not the "Body" containing the "Response"
4 REPLIES 4
Use this code:
  return { pretty };
Hope this helps!
I see some encoding problems in the input (it's passing as a string instead of an object).
Is the input field set to formula mode or text mode? Make sure it's formula. This might fix it.
gsbrown
Excellent, that would have been my follow up suggestion! The "body" is encoded as a string, but the parsed response gets passed as an object.
