โ01-15-2025 07:21 AM - edited โ01-15-2025 08:17 AM
Returns the successor to str. The successor is calculated by incrementing characters starting from the rightmost alphanumeric (or the rightmost character if there are no alphanumerics) in the string. Incrementing a digit always results in another digit, and incrementing a letter results in another letter of the same case. Incrementing nonalphanumerics uses the underlying character setโs collating sequence.
"abcd".succ #=> "abce" "THX1138".succ #=> "THX1139" "<<koala>>".succ #=> "<<koalb>>" "1999zzz".succ #=> "2000aaa" "ZZZ9999".succ #=> "AAAA0000" "***".succ #=> "**+"
Error: I would like to get next number from "SO012501" to "SO012502"
โ01-15-2025 08:38 AM
The succ method isn't supported in the in-line Ruby (in formulas and variables), but it is supported in the Ruby action.
Create a Ruby action with an input called "str" and and output called "result" and then use this code snippet:
{result: input["str"].succ}
โ01-15-2025 08:53 AM - edited โ01-15-2025 08:53 AM
Thank you for the information, that works!
