โ02-12-2025 01:09 PM
I have an API call with a date filter and I want to get the information from the last 30 days. So I created a parameter like this:
today-30.days
and called it "Last30days". Then I added the parameter to my API call to be like this:
my_API_call_?$filter=PostingDate gt {Last30Days}
but it's not working and I'm getting the following error:
"A binary operator with incompatible types was detected. Found operand types 'Edm.Date' and 'Edm.String' for operator kind 'GreaterThan'."
Any idea on what would be the right way to do this?
Thanks!
โ02-17-2025 02:21 PM
Thanks for all of the screenshots and details. Here are my thoughts:
#4 is the most important because this is the last bit of important information that I don't have.
โ02-18-2025 10:10 AM
@gary1 I thought the guided setup was the right way to change something and validate it right away but apparently, it doesn't support everything that was causing the problem.
I've updated the PATH to Text + the Last 30 days parameter from the data pill and didn't change it to Guided Setup for Validation. I've activated the recipe and it ran.
I will spend some time today to validate it and make the change to the other recipes, if it works I will provide another update here.
Thank you!
โ02-17-2025 04:34 AM - edited โ02-17-2025 04:34 AM
Thanks @gary1.
โ02-20-2025 09:02 AM
Hey guys, just to update you on this, it's solved!
The issue was that I was using the guided setup to validate the data resulting from the API call which I believe is the only way to see that data. The thing is, the guided setup doesn't support data pills so that was causing the issue.
So I added the PATH as >>>>> my_API_call_?$filter=PostingDate gt {Last30Days data pill}
Set it as Text (not formula) and that worked.
Thank you very much for the support!
