Jotform Webhook
kbrownsigsolar
Anyone had luck getting the webhook in JotForm to connect to Workato?
Prajwal
Hi @kbrownsigsolar,
Please follow the below steps to setup the Webhook for in the JotForm to connect to Workato.
Step 1: Create a recipe with the Webhook triggerScreenshot 2024-12-10 162459.png
Step 2: Open the form that you have to connect to the Workato to process the submissions:
Example: I've created a sample Appointment form
Step 3: Open the settings tab on the form
Step 4: Click on the Integrations tab in the left hand side
Step 5: search for webhooks in the search bar and click on webhooks tail
Step 6: copy the webhook end point that generated in the workato and past it in the 'Add Webhook' field and click on complete integration and click on Finish
Example:
Step 7: you can now submit the form to check if the webhook is working or receiving the request from the JotForms.
Example webhook payload:
Please follow the above steps to enable the integration with Workato from JotForms. Let me know if you see any issues configuring this. I'm very much happy to assist you!
Prajwal Prasanna
Prajwal Prasanna
Type a product name
