Looping through parsed JSON to get key and value
moxiego
I  have a GET command that returns a JSON response.The next step is Parse JSON. From there, I want to loop through the "key" and "value". The Parsed JSON turns the fields into datapills, which I can pull the value, but I can't get the "key" (label). Is this possible?
2 ACCEPTED SOLUTIONS
Star Chef I
Star Chef I
Create a Ruby action and use the following code. Create an input called "obj" and use the object data pill. It will output an array of objects with key/value keys that are easier to loop through in a traditional Workato loop.
Ruby code:
obj = input["obj"]
array = []
input["obj"].keys.each { | k |
  array.push({"key": k, "value": obj[k]})
{output: array}
Example input object:
{"one": 1, "two": 2, "three": 3}
Output:
	"output": {
		"output": [
				"key": "one",
				"value": 1
				"key": "two",
				"value": 2
				"key": "three",
				"value": 3
moxiego
Thank you! I was able to turn it into python code that worked for me.
def main(input):
data = input.get("jsondata", [])
output_list = []
for item in data:
custom_fields = item.get("custom_fields", {})
for key, value in custom_fields.items():
output_list.append({"key": key, "value": value})
return {'output_q' : output_list}
Prachi_chakke
would mind to answer how can I map these key value to data model?
moxiego
Step 10: In the above code, we get the output_q as the key/value list.
Step 11: "for each item in output_q (prev step) repeat the following steps"
Then I update previously declared variables
Primary Supervisor: KeyStep11.match?(/primary_supervisor/).present?? ValueStep11 : skip
