modify the existing Entra ID connector to add the manager field / attribute
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
โ01-28-2025 07:29 AM
I would like to modify the existing Entra ID connector to add the manager field / attribute. Currently the connector does not support this. The Entra connector is available in the custom connectors and the 3000 line source code is also available. Does any one know how I can add one field to the new / update / delete user triggers and actions for this connector?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ01-28-2025 07:57 AM - edited โ01-28-2025 07:58 AM
Hi @srhodes ,
There are two of achieving it. Here I am assuming you have installed the "Entra" connector in your workspace.
For internal use: Once installed, you have the option to edit it. However, ensure that the specified field name is supported by an API endpoint (request or response) before releasing the latest version. (image_1: Release connector)
For public use (Community Connector): After making your edits, test it thoroughly end-to-end before sharing it with the community. (Image_2 : Share to Community)
Shivakumara A
