New or updated group in Microsoft Entra ID
RESAM
the trigger JSON output provides data on member@delta which I want to use in a next step, but the data is not visible in the datapill.
cheers, Jacques
steps to follow:
1. first switch to formula mode of Document Filed
2. Map the step output pill, as shown in below image attached.
hope you got my point now??
7 REPLIES 7
rajeshjanapati
Hi @RESAM ,
For that you need to do PARSE JSON by providing copy raw json data from step-1 output in sample document and in Document need to pass step-1 output pill.json (like below shown in image) then you can access each pill from Microsoft Entra ID.
hi @rajeshjanapati , thanks for the reply
I will check it out right now!
cheers
hi @rajeshjanapati
I found the action in app "JSON tools by Workato", but was unable to set the required sample document, do you have an example maybe?
Hi @RESAM,
click on Copy raw JSON and paste it in the sample document box and in document map the step-1 output pill as i mentioned above image, in the logger if you check, you can access the data pills of each field, hope you got my point?
