On-prem files - New CSV in folder will trigger no less than every 30 minutes?
scoope
Hi all,
I've built a small recipe to deliver the content of new CSV files in an On-prem into a Google Sheet. This is working fine, but I can't get the recipe to trigger on an interval any less than 30 minutes - ideally I'd like to run it every 5 minutes:
The documentation doesn't seem to suggest a minimum limit on the timer, nor am I restricted in the interval dropdown.
I'm running the latest On-prem Agent version 2.18.0.
scoope
Problem solved. The limitation is only evident when running from a personal Workspace.
1 REPLY 1
scoope
