โ04-01-2023 10:37 PM - edited โ04-01-2023 10:44 PM
Hi all,
I've built a small recipe to deliver the content of new CSV files in an On-prem into a Google Sheet. This is working fine, but I can't get the recipe to trigger on an interval any less than 30 minutes - ideally I'd like to run it every 5 minutes:
The documentation doesn't seem to suggest a minimum limit on the timer, nor am I restricted in the interval dropdown.
I'm running the latest On-prem Agent version 2.18.0.
โ04-02-2023 06:11 PM
Problem solved. The limitation is only evident when running from a personal Workspace.
