โ02-11-2026 07:43 AM
Hello everyone
Want to process 100k records from csv file and dump them in a database
here i'm getting below error
โ02-13-2026 08:54 AM
Hi Rajesh,
Thanks alot for your support actually get lines from csv from workato file storage able to load 50k records at a time we need to take it twice for 100k after that using for each 2 times to dump them in db
let me know is it good practice or not..?
โ02-13-2026 09:32 AM
as per my recipe, from 4th step you will get 50K records, after that based on batch size supported by your DB take for each action if doesn't supports 50K records to load into DB or directly map 50K records to DB. hope you got my point?
FOR-EACH action is considered based on batch size supported by DB otherwise not needed.
