Put CSV Output on New Lines ?
dunncrew
I am reading 1 text field from a SQL Server select rows and want to send them in an email. Currently, it puts all the records on one line, but I want each record on a new line. Any suggestions ? I tried to force a "New line" break, but no luck.
See Screen-shots and result data (3 records sample) below.
Instead of this
    10/11/2023  10:16     Jones, Mary,   Computer Room    ,    10/11/2023  10:54     Smith, Frank,   Computer Room    ,    10/11/2023  15:56     Amos, Henry,   Computer Room
I want
dunncrew
Thanks. I think the output is correct when I do this:
But after the next step to send the email
I get this error.
Also, It looks like I can "trick" it into making a 2 dimensional array by PLUCKing a blank instead of a 2nd field, but it puts a comma off to the right to separate the imaginary 2nd blank field from valid field 1
P.S.  Thanks for all your help the last few days !
8 REPLIES 8
When you pluck a single field, the result is a flat array of values, so using to_csv creates a CSV with a single row (no line breaks).
If you add a second value to your pluck it will make a two-dimensional array (an array of arrays), and to_csv will add line breaks between each secondary array.
If you don't want to pluck a second value, you can drop to_csv and use [rows].pluck('output').split('\n')
dunncrew
I get this error.
Try setting the body input to text and not formula mode.
No problem! Happy to help : )
dunncrew
No error, but my email result is this:
[["10/11/2023  10:16     Jones, Mary,   Computer Room                                              ", "10/11/2023  10:54     Smith, Frank,   Computer Room                                              ", "10/11/2023  15:56     Amos,Henry,   Computer Room                                                   "]]
