Returning a result from a callable recipe
edward-abrahams
Hey all, wondering if I could get some advice on using callable recipes. I've set one up where my result schema is a single object. I then have a Python script that also outputs an object (also defined in the Workato schema.) Problem is, when I try and set the result, I can't pick anything. See here:
I can't quite get my head around why it won't accept it seeing as it's all the same type. Any ideas?
Edit: I've found if I change the input schema to text, it will let me pick the data, seems to be the type causing the problem
13 REPLIES 13
kobi-sh
Hi, you need to change it from Text to Formula.
Then you'll be able to map "Data" to "Data".
edward-abrahams
Thanks Jacob Shmerkovich - that was my first thought, but the "Return" action doesn't give me the option to switch between text and formula
kkrivonos
Edward, just select the "Data" on the left side and drag it into "Data" to the right. You can drag the selection although there is no datapill shown!
This doesn't work for me, I can drag it like you've shown, but it doesn't do anything
