SAML based SSO setup using Azure AD
CA2020
Hi Pros, do we need to setup SAML based SSO setup in AD for each environments as the Sign on URL asks for workspace id which is specific to each environment. Please advise on the best way to set it up.
gibson-cabello
Hi there!
Thanks for reaching out!
That is correct! You need to create different SAML apps for each environment.
You can get the Workspace ID from the Workspace Admin > Settings > Authentication & Provisioning if you are a workspace admin.
This Workspace ID is auto-generated but you can change it anytime.
After retrieving the workspace ID, you can append that to the sign-on URL of the SAML app.
I hope this helps!
gibson-cabello
Hi there!
I hope this helps!
