โ03-06-2024 10:16 AM
I am using the On-Prem Agent functionality. When set up, this OPA requires that I specify a Base Folder.
Is this Base Folder Path value available for use (eg as a datapill) in a Formula??
โ03-06-2024 12:02 PM
It's not possible as far as I understand. There is a good news though. Your steps working with this connector should be moved to a functional recipe and 'Runtime user connections' should be switched on like this:
After doing this, in the parent recipe where you call function recipe you will get this parameter
Here you will be able to use formula, lookup table etc
โ03-11-2024 06:32 AM
I have opted to create an Environment Variable for the Base Folder Path that I can reference in Recipes.
