String value in list with options
AMacourek
I have a list with the following schema:
I would like to have the dataType be a list of values to pick from when adding items to the list.  How can I achieve this?
First, change the control_type to "select" or "multiselect"
Then, add a "pick_list" key. For the value, make an array of nested primitive arrays with two items. In each nested array, the first item is the label, the second item is the value that passes for each option.
Like this:
    "control_type": "select", ## or multiselect
    "label": "Dropdown",
    "name": "dropdown",
    "type": "string",
    "optional": false,
    "pick_list": [
      ["one",1],
      ["two",2],
      ["three","hello"]
More info here:
https://docs.workato.com/en/developing-connectors/sdk/sdk-reference/schema.html#attribute-descriptio...
And here:
https://docs.workato.com/en/developing-connectors/sdk/sdk-reference/picklists.html
Like this:
    "name": "dropdown",
    "type": "string",
    "optional": false,
    "pick_list": [
      ["one",1],
      ["two",2],
      ["three","hello"]
More info here:
And here:
Thanks.  I must have just had the syntax wrong
