Workato Scheduler
yu-shao
Hi I am a newbie here. If I set a scheduler to trigger every 5 minutes, but the whole recipe is taking more than 5 minutes to finish. I was wondering what is happening behind the scene. The next trigger will be exactly after 5 minutes or it won't trigger until the previous job finishes. If the next trigger runs and the previous job has not finished yet, is it gonna have a new job running while the previous job is still running?
7 REPLIES 7
yu-shao
Thanks Joseph Blanchett I don't see any settings available to set the recipy concurrency.
You may not have multiple con currencies available in your instance then. If thatโ€™s the case itโ€™s probably safe to assume that the concurrency is always 1 and you can run the test I mentioned above to see what happens.
check for Settings tab while you're in view mode on the recipe.
