3 weeks ago
๐ง Workato Tip of the Day: Avoid XML Pitfalls with Reserved Keywords!
Did you know? In Workato, using <command> in an XML message template might show a red mark at the bottom. ๐ฉ This happens because command may be reserved keyword in Workato. ( image attached #image_1: Before fixing the issue and ##Image_: After fixing the issue)
๐ ๏ธ Quick Fix:
Add a prefix or suffix, like <commands> or <name_command>, to avoid red mark.
โ
Making this small tweak ensures smoother workflows and error-free integrations.
Stay ahead with these handy tips! ๐กโจ
This simple adjustment can make your XML integrations error-free and reliable. Keep this in mind for your next project! ๐
2 weeks ago
Hi @Prudvi,
Workato XML Processing Logic vs JSON Processing Logic:
XML: Workato's XML engine may enforce stricter validation rules or reserve certain tags for internal use due to XML's hierarchical structure and metadata handling. Tags like `command` could trigger errors during parsing if they conflict with system-defined keywords.
JSON: Workato treats JSON as a more flexible data structure and doesnโt enforce strict naming rules, allowing keys like command without issues.
This is my understanding on the JSON and XML parsing logic. Hope I have answered your question.
2 weeks ago - last edited 2 weeks ago
Hi Shiva,
I have tried to create a message template using JSON format and I don't see the error message as mentioned in the above article.
Any reason why workato is only considering command as a reserved keyword for XML not for JSON.
Siddhartha
2 weeks ago
Hi @Prudvi,
2 weeks ago
Hi Shiva,
Thanks for the response.
wanted to confirm, all the components created in workato are internally converted to XML.
Siddhartha
2 weeks ago
Hi Prudvi,
Not necessarily, it is purely depends on which component we are using.
