2 weeks ago
๐ง Workato Tip of the Day: Avoid XML Pitfalls with Reserved Keywords!
Did you know? In Workato, using <command> in an XML message template might show a red mark at the bottom. ๐ฉ This happens because command may be reserved keyword in Workato. ( image attached #image_1: Before fixing the issue and ##Image_: After fixing the issue)
๐ ๏ธ Quick Fix:
Add a prefix or suffix, like <commands> or <name_command>, to avoid red mark.
โ
Making this small tweak ensures smoother workflows and error-free integrations.
Stay ahead with these handy tips! ๐กโจ
This simple adjustment can make your XML integrations error-free and reliable. Keep this in mind for your next project! ๐
Tuesday
Hi @Prudvi,
Workato XML Processing Logic vs JSON Processing Logic:
XML: Workato's XML engine may enforce stricter validation rules or reserve certain tags for internal use due to XML's hierarchical structure and metadata handling. Tags like `command` could trigger errors during parsing if they conflict with system-defined keywords.
JSON: Workato treats JSON as a more flexible data structure and doesnโt enforce strict naming rules, allowing keys like command without issues.
This is my understanding on the JSON and XML parsing logic. Hope I have answered your question.
Tuesday - last edited Tuesday
Hi Shiva,
I have tried to create a message template using JSON format and I don't see the error message as mentioned in the above article.
Any reason why workato is only considering command as a reserved keyword for XML not for JSON.
Siddhartha
Tuesday
Hi @Prudvi,
Tuesday
Hi Shiva,
Thanks for the response.
wanted to confirm, all the components created in workato are internally converted to XML.
Siddhartha
Tuesday
Hi Prudvi,
Not necessarily, it is purely depends on which component we are using.
