xml and json Transformaion
amit_mohanty88
I want to achieve below functionality in Workato without Ruby / Java Script / Python Scripting as scripts are not allowed by our customer .Also JSON Transformations by Workato Action not available in my plan .Without these is there a way to acheive below ?
1) Sort a input json alphabetically ascedending
2) Remove any specific fields from a input json and return updated json
3)Convert any given input  json to xml and any given input  xml to json
4) Compare 2 json elment structure and return any field mismatch between the 2 json which is present in 1 json not the other json
10 REPLIES 10
rajeshjanapati
HI @amit_mohanty88,
Have you tried using SQL Collections by Workato?? like below
Thanks,
J Rajesh Kumar.
Hi @rajeshjanapati
  1. We can combine steps 4 and 5, as the sorting part is not being used in any subsequent steps.
  2. For XML ↔ JSON conversion, we can directly feed the data into Parse XML and Parse JSON action/ step as needed.
This approach will help optimize the overall solution. Please free to add your thoughts.
Hi @shivakumara ,
Thank you for your valuable suggestion and the additional step.
Here’s my thought process:
  1. As per @amit_mohanty88's question, the goal was to verify whether each scenario is possible or not. Hence, I designed the flow in such a way to demonstrate all the possibilities.
  2. Agreed with your point regarding optimization.
Thanks again for your inputs!
Thanks & Regards,
J Rajesh Kumar.
amit_mohanty88
Hi @rajeshjanapati
Let me try and get back . Thank you for your suggestion
