01-24-2025 08:59 AM - edited 01-24-2025 08:59 AM
Hi team,
My workflow apps was working fine till this morning and now I'm getting error 'Page cannot be saved', even though I haven't made any changes to the current flow
01-25-2025 12:10 AM
Hi @ron94 ,
Would you mind clarifying where exactly are you getting the error? What were you trying to do when the error showed up? Are you trying to submit a form or is it when you try to save the changes you've made to a page? If it's the latter, please check the properties of each component on your page to ensure they are correctly configured. This includes verifying that all required fields are filled out and that any conditional visibility or editability settings are correctly set.
01-27-2025 12:49 AM
Hi @elinor-aquino ,
I'm getting the error when trying to update a already submitted form- as I'm using the original form data table column reference to fill in another data table. I haven't made any changes to my previous flow which was working as expected - The error I'm getting is -
