IF … ELSE IF… ELSE IF… ELSE IF… ELSE…
We're happy to announce the enhancement of our conditional control statement.
What’s new
- Now there is one conditional step IF condition instead of confusing two.
- Users can add or remove else if or else conditions to existing if condition at any moment without needing to recreate the conditional logic (as it was before).
- Users can reorder else if conditions inside a single conditional block.
How does it work?
- Any conditional logic starts with IF, so users must create the first logic block first.
- After the first condition is added and the user wants to add other conditions below, clicking “add step” will show a panel with two more options: “ELSE IF” and “ELSE” that can be added to the previous conditional logic.
Check out the Web Documentation →
Platform Ops' latest releases
Here is a summary of the latest feature releases and enhancements for the Platform Ops product area. We hope they improve your day-to-day work on the system and reduce some manual work! Let us know what you think.
Time and date formats - New feature!
Now, you can customize your settings to see the Workato platform in the date and time format you are used to working (and thinking) in - saving you the time you spend figuring out what those numbers on the screen mean. New time and date formats are:
- mm/dd/yy h:mm AM/PM.
- mm/dd/yy hh:mm.
- dd/mm/yy h:mm AM/PM.
- dd/mm/yy hh:mm.
Check our Docs.
Developer APIs
- GET Job API: New fields were added to improve the visibility of errors: error count, step, app, action, and retry count.
- New API option to export and import! Now, all you need to do is provide a folder ID. If all assets are in the same folder, then no more IDs for each asset you want to add to the manifest.
- Create and Update recipe API - new field to update recipe description.
API collections & endpoint
- The collections page and endpoint cards have a fresh look, featuring new icons to easily distinguish API recipes and API proxy endpoints.
- (The most exciting part) Recipe endpoints—once you click on an endpoint, you can immediately see the API request and response schema, recipe actions, and key endpoint configuration.
- Previously, users would have to navigate to the recipe to see this.
- Endpoint settings
- We've created a new 'endpoint settings' tab. This gives users a persistent view of key endpoint configuration settings without navigating to the 'edit endpoint' pop-up.
- Note: This is a temporary state. As part of our API proxy transformation project, we'll be adding more capabilities to the settings page.
UI enhancements
- Job history page: Due to performance issues and long loading times in some cases, we introduced a new default for the time filter. It is now set for "last 30 days" by default, improving the experience working on this page, especially for heavy recipes.
- Deployments tab: More time filters are now available, enabling users to see deployment history older than the last 30 days.
Some fixes
- Notification emails: We added the workspace name (the correct one) to the notification alerts users get from Workato so they can easily recognize the relevant workspace.
- Scheduler: During Jan-Feb, we improved the scheduler's timezone logic (it had some bugs). As part of the fix, we made the timezone a mandatory field. This has been fixed back to being an optional field due to the requests from the field.
- ALR: Preventing customers from selecting the wrong configurations.
Coming up soon:
- Job history table download.
- Manifest page UI improvements.
- LUT page UI improvements.
- Improved assets search - text search will also search through the description, apps, and actions.
Field Connectivity Team Updates
Here are the latest community connectors and recipe updates!
What’s new on Product Hub:
Recipe Highlight:
New/Updated Connectors:
AWS Bedrock
Kintone
iChris (Static)
JobAdder
Camplife
Aimtec ClouEDI
JD Edwards
Backlog
MYOB Advanced
Acumatica
SugarCRM
Harvest
Workato Embedded
Freshsales
ClickUp
Amazon Kinesis
Freshservice
HiBob
Sage Intacct (Custom)
Personio
GraphQL
Check out our Product Hub →
