Automation Quality & Security Accelerator
Workato’s Automation Quality and Security (AQS) accelerator provides a framework to standardise recipe development best practices and report on the non-adherence of recipes/deployment packages concerning the defined best practices. This accelerator solves some of the compliance check problems as there is: No easy way for IT to check adherence to best practices.
No metrics to identify non-adherence to best practices.
No easy way for recipe builders to know whether they are adhering to internal best practices set by IT.
When to use it?
The best practices can span across many design paradigms, e.g. standards, conventions, security, etc. Some of the key consequences of not automating quality and security checks are:
In the absence of an automated way to govern quality, the quality and security of the deliverables must be validated manually. Although this can be achieved, it can be a very time-consuming exercise.
The problem gets aggravated in the case of large enterprises that intend to democratise automations or achieve wall-to-wall automations and, as a result, are enabling both business and IT teams to build more automations faster. In this case, it becomes almost impossible to manually do a sanity check on the quality of all the deliverables.
As a result, this could result in a lack of governance, which eventually could result in performance degradation, unwanted errors and poor customer experience over time
Check also this 3-minute video . Contact your CSM if you want to have access to this accelerator package.
See Documentation
Asset Tags - Organise across Teams and Projects
I'm happy to announce that Asset tags have just been released for all our customers. They bring a
new level of organisation to the customers’ workspaces: categorise, search, and filter recipes, connections, pages, and data tables – across all projects.
Small tips:- All environments share a single tag list. By default, any collaborator can create and assign tags. Workspace admins can configure tag permissions for greater control.
- All modifications with tags are stored in AuditLog.
- Customers can add/edit/assign/delete tags using Dev API endpoints.
- RLCM allows collaborators to save tags during export/import packages.
- Tags might be used in RecipeOps to filter in the Recipe Start trigger.
We will gladly collect feedback about actual use cases to better understand the improvement priority.
Field Connectivity Updates - September
In September, we released 22 connectors and a new Recipe Highlight to the Community Library!
Recipe Highlight:
New Connectors:
- Google Meet
- DATEV (Booking Data Service)
- AWS GuardDuty
- Kite Platform
- Formstack
- WooCommerce
Connector Enhancements:
- Backlog
- Google Gemini
- DealCloud
- Sage Intacct (Custom)
- HL7
- SOAP
- SAP Business One
- Shopware
- MYOB Business
- Kintone
- Google Slides
- LaunchDarkly
- GraphQL
- Google Ads
- Duo Security
- SAP Business One
Check Detailed Release Notes
