Add a Category to Email after retrieving attachment using Outlook Connector
ccontzen
Dear all,
is there a way to set a category to an email using the outlook connector after downloading attached pdf files?
its basically the same as described here:
Stackoverflow: Add Outlook Category to mail via MS Graph
Thank you in advance
Christian
kelian-mos
Hi @ccontzen,
This is not supported by default, but through the custom action in the Outlook Connector you can achieve this:
The Outlook Connector is using the MS Graph API as listed here:
https://learn.microsoft.com/en-us/graph/api/message-update?view=graph-rest-1.0&tabs=http
In this custom action I'm using the following parameters:
Method: Patch
Pathhttps://graph.microsoft.com/v1.0/me/messages/{id}
Request: {"categories":["name"]}
Let me know if this works and is what you meant.
kelian-mos
Hi @ccontzen,
Method: Patch
ccontzen
Thank you for your support - it looks like it is not possible to shared mail accounts.
We are downloading attachments from a shared account and want to set a category to processed  mails. Looks like its not possible...
You can't do it using delegate permissions because there is no MailboxSetting.ReadWrite.Shared permission so that endpoint can only be used to access the current users Mailbox setting when using delegate permission. You an use Application Permissions and the Client Credential flow https://learn.microsoft.com/en-us/azure/active-directory/develop/v2-oauth2-client-creds-grant-flow if you need to limit the scope of your application to a number of Mailboxes you can do that as well https://learn.microsoft.com/en-us/graph/auth-limit-mailbox-access
microsoft graph api - MSGraph API: How to get outlook categories of other user as described in the A...
