Adding items to a nested list
dkollar
I have a recipe that pulls data by a specified date range.
Sample data parsed from a list variable:
  "data": [
      "Id": "1234",
      "Items":
          "Item": "Placeholder Item"
      "Id": "1234",
      "Items":
          "Item": "Placeholder Item 2"
      "Id": "5678",
      "Items":
      "Id": "5678",
      "Items":
What I would like is to format the data in this way:
  "data": [
      "Id": "1234",
      "Items": [
          "Placeholder Item",
      "Id": "5678",
      "Items": [
          "Placeholder Item",
I want any Items that have the same Id to be combined under a single Id. Any ideas how this can be done?
You can do this in a Ruby action using the below code. This way you don't have to loop through your array and burn a whole lotta tasks :
data = []
records = input["array"]
ids = input["array"].pluck('Id').uniq
ids.each { | id |
obj = {}
items = []
records.each { | record |
if record["Id"] == id
items.push(record["Items"]["Item"])
end
obj["Id"] = id
obj["Items"] = items
data.push(obj)
{data: data}
Parse your JSON input first and then set up the Ruby action like this:
Output:
1 REPLY 1
data = []
ids.each { | id |
obj = {}
items = []
end
obj["Id"] = id
data.push(obj)
{data: data}
Output:
