Custom connector
sampath
I have built a custom connector for my company and now I need to import that to my client's portal. I have shared a private link for my custom-build connector.
does anyone know how to import it to the client's environment?
sampath
marlon-muela
Hi
Once you have the Custom Connector Sharing URL (private link), you can share this with your client, and they will have the option to Install the connector on their workspace once they open the link.
Thanks for the clarification. Suppose you will be using an SDK across a different Data Center; I would advise using Recipe Lifecycle Management to Export the recipe and SDK connector. It will create a manifest, which you can import to another account from a different data center.
Here's a sample of the manifest:
6 REPLIES 6
marlon-muela
Hi
Thanks @marlon-muela  But the problem is, when are working with 2 different data centers where is the install options?
for example:
my private link is : https://app.workato.com/custom_adapters/488708?token=77d006
And I need to install on : https://app.sg.workato.com/
ahanumantharaya
@sampath  You can ask Support team to publish your custom connector in various region. Currently they publish it in region where your instance is.
