Export lookup table data
Ralef
I've found a problem when I've wanted to automate exporting my lookup tables and save them in S3. I have a simple formula for S3 content:
[Entries].pluck('entry').to_json
And what I was expecting to get from it is
   "some_field1": 123,
   "another_field": "1qwer",
In reality it replaces column names with col1, col2, col3, so it looks like that
  "col1": 123,
  "col2": "1qwe",
Is there any way to persist column names or map them back?
The quickest way to do this is to make a variable list with the key names you want and then map the LUT response into the list. It should only require one additional task.
Ralef
Yes, that was the solition, thanks!
Hi @Ralef ,
Check out this solution does this helps you or not, it will not take any additional task too.
Explanation:
We can define the column as per our requirement using 'format_map' at the end we can format using to_json.
Shivakumara Avadhani
