How do I enter values into Workato's OpenAI Custom Action?
JayMappus
I used the "guided setup"  but I cannot figure out how to add datapills to the "Request body parameters" it created. Below is how I configured using the Guided Setup:
Setup OpenAI custom action from sample request
  Request type = JSON request body
  Response type = JSON response
  Request body
{ "model": "gpt-4o-mini", "messages": [{"role": "user", "content": "Say this is a test!"}], "temperature": 0.7 }
Request headers:
Content-Type: application/json
Authentication: XXXX____XXX
Then clicked the "Send request" button and received a 200 - ok of the following Response Body:
object: chat.completion,
created: 1738194916,
model: gpt-4o-mini-2024-07-18,
choices:
index: 0,
message:
role: assistant,
content: This is a test! How can I assist you further?,
refusal: null
logprobs: null,
finish_reason: stop
usage:
prompt_tokens: 13,
completion_tokens: 13,
total_tokens: 26,
prompt_tokens_details:
cached_tokens: 0,
audio_tokens: 0
completion_tokens_details:
reasoning_tokens: 0,
audio_tokens: 0,
accepted_prediction_tokens: 0,
rejected_prediction_tokens: 0
service_tier: default,
system_fingerprint: fp_72___b54c
But when I go to add values (either datapills or constants) to the fields, there is no place to put / enter them. The Input / "Request body parameters" have no input fields for the datapills.
I feel that I'm missing something obvious but the support docs and ChatGPT isn't helping.
Thank you
Hi @JayMappus,
I’ve outlined the details of my approach along with my inputs below:
1. Guided Setup (See Attached Images):
-->  This is a straightforward and user-friendly method to configure the endpoint.
Steps to follow:
- Select Guided Setup:
- Choose the Method (POST)
- Specify the Path(e.g., `chat/completions`)
- Define the Request Type (JSON Request Body)
- Set the Response Type (JSON Response)
- Provide the Request Body(JSON structure)
- Configure the Request Header(Content-Type & Authorization)
-->  Once the request is sent:
- A successful response (HTTP 200) confirms proper setup.
- Workato automatically handles the request and response structure during the guided setup process.
2. Manual Setup (See Attached Screenshots):
--> Steps to configure manually:
- Select the Method (POST)
- Specify the Path(`chat/completions`)
- Define the Request Type(JSON Request Body)
- Manually construct the Request Body based on the API specifications
- Configure the Request Header (Content-Type & Authorization)
- Unlike the guided setup, you need to manually configure the request and response structure using sample data from the API documentations.
Shivakumar K A
Guided Set up_request Taken care by WorkatoGuided Set up_request Taken care by Workatoguided_2.PNGRequest headerRequest headerRequest BodyRequest BodyManually adding request from sample JSON StructureManually adding request from sample JSON StructureOption to provide inputOption to provide inputGuided set up response auto added by Workato at the end point responseGuided set up response auto added by Workato at the end point response
Hi @JayMappus ,
I'm glad to hear the solution worked for you—it's a pleasure to be of help!
Shivakumara K A
