How to skip null objects in a list
nitishjain
I'm getting null objects in my filtered list. how can I remove the null objects w/o using Pythion script?
Example:
[{"name" : "Nitish",
"Id": "010"},
{"name" : "Nitesh",
"Id": "020"}]
Hi @nitishjain ,
Once you receive the filtered response( includes empty items) use again the parse Json where need to pass following way
1. Add the sample response you receive as as sample request. ( your List response)
2. pass the actual array response in the below format.
Shivakumar A
5 REPLIES 5
Hi @nitishjain ,
Just use below solution in formula mode, Please let me know if you need further information.
Shivakumara A
in logger it removes by using "- [{}]" but how do I remove it in actual?
Hi @nitishjain,
What do you mean by 'actual'? Could you please ask the question more precisely?
Shivakumar K A
HI @shivakumara
Thanks for checking, I have a parse json where I'm creating a json structure and later on I'm using list where I checks some condition in all fields and get some empty objects in filtered response.
now I want to remove those empty objects.
Please let me know an optimized  solution.
let me know if you want more details or we can connect over a call.
Nitish
