Insert "Batch of Rows" to Airtable
dunncrew
Hi, When writing records to SQL, I see an option to insert a "Batch of Rows", but I don't see that "batch" option in Airtable, so I am guessing I have to write 1 row at a time somehow ? Probably just 10 - 20 records when it runs.
Any suggestions?
3 ACCEPTED SOLUTIONS
GrailAutomation
Hi @dunncrew! The Workato connector for Airtable natively supports creating 1 record at a time... but it also includes a Custom Action, which you could use to insert a batch of records (up to 10 at a time, according to Airtable's API documentation). Instructions:
  1. Add action to your recipe (app = Airtable, action = Custom Action)
  2. In the action setup, click Start Guided setup
  3. Method = POST
  4. Path = https://api.airtable.com/v0/{baseId}/{tableIdOrName}
  5. Request body =
    "records": [
        "fields": {
          "Address": "333 Post St",
          "Name": "Union Square",
          "Visited": true
        "fields": {
          "Address": "1 Ferry Building",
          "Name": "Ferry Building"
6. Response body =
  "records": [
      "createdTime": "2022-09-12T21:03:48.000Z",
      "fields": {
        "Visited": true
      "id": "rec560UJdUtocSouk"
      "fields": {
      "id": "rec3lbPRG4aVqkeOQ"
That should do the trick โ€” lmk if any issues!
GrailAutomation
Oh โ€” also worth noting the Airtable API supports syncing up to 10K rows if you push a CSV.
dunncrew
AirTable has a restriction on how many INSERTS can occur in a time-frame. So I decided to insert 1 at a time in a loop, and include a WAIT delay to insert slowly.
GrailAutomation
  3. Method = POST
  5. Request body =
    "records": [
        "fields": {
          "Visited": true
        "fields": {
6. Response body =
  "records": [
      "fields": {
        "Visited": true
      "fields": {
GrailAutomation
dunncrew
