The message you are trying to access is permanently deleted.
โ04-05-2024 03:10 AM
I have a usecase, when a number of jobs failed for a recipe, then after resolving the issue, I can click on all failed jobs and select repeat jobs. My question here is, can repeat jobs follow the FIFO or not? Will jobs be repeated in the earlier order or not?
โ04-08-2024 03:49 AM
Hi Inderjeet,
When you select all jobs and click on "repeat jobs," the system might not strictly follow the FIFO principle. Instead, it will execute jobs based on their individual requirements and the time needed for each job to complete. This means that a job that takes longer to execute might be processed before a job that arrived earlier but can be completed more quickly.
Hi Inderjeet,
