12-12-2025 01:50 PM
Hello!
I am new to Workato. I am attempting to create a suite of data transformation recipes. Everything works as expected until it come time to update the transformed data to the lead records in Marketo. Depending on how I attempt the update, I get a variety of error messages. But I am wondering if our Marketo instance is the issue.
We are configured to match leads based on two fields in list uploads and API calls - 'email' and 'company'.
Is this the issue and is there anyway to get the integration to work with this Marketo requirement? I tried joining the two data pills in the "lookup field" but that clearly did not work.
Thanks!
Edward
12-23-2025 02:38 AM
Hi @ecamarillo
Can you state the issue in more detail.
I understood that you are trying to update the record in Marketo using the email and company right.
Are you using the Webservice to update the transformed data into Marketo.
