02-15-2024 02:24 PM - edited 02-15-2024 02:25 PM
How can I display all my Pages under my Facebook login? - I'm facing the issue below.
I had several recipes using the Facebook Lead Ads trigger and while they looked to be working fine when I clicked to edit the trigger they gave me an error of "Specified page with id xxxx not found". When I tried to correct it, the trigger said there were "No items" to choose from in the Page's choice set. Below is a test of the trigger that I was doing that captures it in context.
I had not changed anything in Facebook nor in the triggers yet this suddenly happened. I thought it might somehow be an issue with the configuration within Facebook. To test that theory I set up a trigger in Zapier to see if it would have the same issue. It did not. I was able in Zapier to create a Zap using the Facebook Lead Ads trigger to pull back all Pages and Forms. What can I be doing wrong?
03-13-2024 04:41 AM
Hi, here are the troubleshooting steps for this issue:
If the issue persists, could you please try to test it here?
03-13-2024 04:41 AM
