Regular Expression with Workato Lookup Table
hendrykurnia
Hi guys,
I have a use case where I use regular expression to validate the input of postal code.
E.g. Formula = "95000-2707".match?(/(^\d{5}$)|(^\d{5}-\d{4}$)/) for matching the US postal codes.
However, this method won't work if the regular expression is stored in a lookup able.
E.g. "regular_expression" lookup table
countryregex
United States/(^\d{5}$)|(^\d{5}-\d{4}$)/
Formula = "95000-2707".match?(lookup("regular_expression", "country": "United States")["regex"])
I have also tried the following formula but no luck.
"95000-2707".match?(lookup("regular_expression", "country": "United States")["regex"].to_s)
- "95000-2707".match?(/lookup("regular_expression", "country": "United States")["regex"]/) and "95000-2707".match?(/lookup("regular_expression", "country": "United States")["regex"].to_s/) with the following lookup table
countryregex
United States(^\d{5}$)|(^\d{5}-\d{4}$)
Thank you
hendrykurnia
Thanks Gary.
I would like to share what I have found. Actually, removing the '/' at the beginning and end of the regex in formula syntax and lookup table works.
countryregex
Give it a shot
You would be able to do this with the Ruby "send" method, something like this:
[postal_code].send("match", regex)
But alas, Workato doesn't support "send".
However, you can still do this with a JavaScript action.
Set it up like this:
And use this code:
exports.main = async ( {term, inputRegex}) => {
  var reg = new RegExp(inputRegex);
  result = reg.test(term);
  console.log(reg);
  return { result };
Hope this helps!
hendrykurnia
Thank you Gary.
I tried this out and worked. Quick question, I'm trying to map and update batch of 100+ records in this use case. With this method, is there a way I can map the batch record?  Or do I need to loop each record to with the Javascript action?
Glad this worked.
It's possible to do this in batches. Here's the updated code.
The postal_codes input is an array of postal codes and countries. You'll need to match this format from your source data.
The lookup_table input is the entire lookup table (use the "Get all entries from..." action)
And here's the updated code:
exports.main = async ( {postal_codes, lookup_table} ) => {
  console.log(postal_codes);
  const lut = lookup_table;
  const response = [];
  postal_codes.forEach(function (i) {
    console.log(i);
    let pc = i.postal_code;
    let c = i.country;
    let match = lut.filter(function(l) {
      return l.entry.col1 == c;
    let reg = new RegExp(match[0].entry.col2);
    let result = reg.test(pc);
    let resultObj = {
      postal_code: pc,
      country: c,
      regex: reg,
      result: result
    response.push(resultObj);
  console.log(response);
  return { response };
FYI, there's no error handling in this, so if the lookup fails, the whole thing might crash. JavaScript is not my native tongue ๐Ÿ˜›
hendrykurnia
Thanks Gary.
countryregex
Give it a shot
