โ06-04-2024 04:35 PM - edited โ06-04-2024 04:38 PM
Hi guys,
I have a use case where I use regular expression to validate the input of postal code.
E.g. Formula = "95000-2707".match?(/(^\d{5}$)|(^\d{5}-\d{4}$)/) for matching the US postal codes.
However, this method won't work if the regular expression is stored in a lookup able.
E.g. "regular_expression" lookup table
country | regex |
United States | /(^\d{5}$)|(^\d{5}-\d{4}$)/ |
Formula = "95000-2707".match?(lookup("regular_expression", "country": "United States")["regex"])
I have also tried the following formula but no luck.
- "95000-2707".match?(lookup("regular_expression", "country": "United States")["regex"].to_s)
- "95000-2707".match?(/lookup("regular_expression", "country": "United States")["regex"]/) and "95000-2707".match?(/lookup("regular_expression", "country": "United States")["regex"].to_s/) with the following lookup table
country | regex |
United States | (^\d{5}$)|(^\d{5}-\d{4}$) |
Thank you
โ06-05-2024 10:23 AM
Thanks Gary.
I would like to share what I have found. Actually, removing the '/' at the beginning and end of the regex in formula syntax and lookup table works.
country | regex |
Give it a shot
โ06-04-2024 07:25 PM - edited โ06-04-2024 07:25 PM
You would be able to do this with the Ruby "send" method, something like this:
[postal_code].send("match", regex)
But alas, Workato doesn't support "send".
However, you can still do this with a JavaScript action.
Set it up like this:
And use this code:
exports.main = async ( {term, inputRegex}) => {
var reg = new RegExp(inputRegex);
result = reg.test(term);
console.log(reg);
return { result };
Hope this helps!
โ06-05-2024 08:48 AM
Thank you Gary.
I tried this out and worked. Quick question, I'm trying to map and update batch of 100+ records in this use case. With this method, is there a way I can map the batch record? Or do I need to loop each record to with the Javascript action?
โ06-05-2024 09:48 AM - edited โ06-05-2024 09:49 AM
Glad this worked.
It's possible to do this in batches. Here's the updated code.
The postal_codes input is an array of postal codes and countries. You'll need to match this format from your source data.
The lookup_table input is the entire lookup table (use the "Get all entries from..." action)
And here's the updated code:
exports.main = async ( {postal_codes, lookup_table} ) => {
console.log(postal_codes);
const lut = lookup_table;
const response = [];
postal_codes.forEach(function (i) {
console.log(i);
let pc = i.postal_code;
let c = i.country;
let match = lut.filter(function(l) {
return l.entry.col1 == c;
let reg = new RegExp(match[0].entry.col2);
let result = reg.test(pc);
let resultObj = {
postal_code: pc,
country: c,
regex: reg,
result: result
response.push(resultObj);
console.log(response);
return { response };
FYI, there's no error handling in this, so if the lookup fails, the whole thing might crash. JavaScript is not my native tongue ๐
Thanks Gary.
country | regex |
Give it a shot
