SAP OData trigger not picking up new events
bart-ejdys
Hi everyone,
I have a problem with using the SAP OData connector as a trigger. I'm trying to build a simple recipe triggered by record creation/modification in SAP S4H. Connection seems to be working fine. I make changes in SAP (modifying a Business Partner record) via GUI. Once I start the recipe for first time, the trigger fires with the latest change event (even if there were more within 1 hour) that occurred before starting the recipe. Then, when I try to trigger the recipe by making more changes to the record, no more jobs appear.
Has anyone had this problem? I kinda ran out of ideas where to look for the root cause.
marlon-muela
Hi @bart-ejdys ,
Can you confirm if you are using New/updated object trigger in SAP OData? If yes, it should pick up new or updated records.
Next is check if you have properly configured the Trigger setup on when it will start picking up events as well as the Timestamp cursor. See image below:
You can also clone the recipe to adjust the pickup events from on a later date. Then, start the recipe and see if it starts picking up the events.
meghan-legaspi
Hi @bart-ejdys,
Can you please share a screenshot of your recipe as it is now?
marlon-muela
Hi @bart-ejdys ,
