โ02-14-2025 08:02 AM
I am very new to this. But let me explain the issue I am having. I have sales Order Lines records as datapills and now I want to add the data dynamically in Send HTTP Request which I am not sure.
I thought to use for each loop and put HTTP inside that but this HTTP calls through the loop is overwriting the previous addition and at the end, I just get only one record.
This is how I am using and this HTTP request is overriding one at the time and giving only last row result
If you see I get 3 rows from search:
and In the foreach. Send Request HTTP took the last row and overriding previously runs.
What I found the solution through postman that I can add all 3 rows in json format and it works in Postman and I don't know how to add it dynamically in Send request via HTTP.
This is how I added in HTTP request:
โ02-17-2025 04:32 AM
Hi @vishalPse,
Can you refer this https://systematic.workato.com/t5/workato-pros-discussion-board/dynamic-output/td-p/8795 which might be similar request.
