Tuesday
I'm trying to request a Twilio recording file using Workato's HTTP request. But, I'm getting the following error:
400 Bad Request
<?xml version='1.0' encoding='UTF-8'?>
<TwilioResponse><RestException><Code>20001</Code><Message>Bad request</Message><MoreInfo>https://www.twilio.com/docs/errors/20001</MoreInfo><Status>400</Status></RestException></TwilioResponse>
Below is my request:
"request_name": "Request recording file",
"request": {
"method": "GET",
"url": "https://api.twilio.com/2010-04-01/Accounts/A_______________________0/Recordings/R___________________..."
"response": {
"output_type": "rawdata",
"ignore_http_errors": "false"
"wait_for_response": "false"
I've got the "Response content type" set to Binary and the Encoding to UTF-8. What am I missing?
Thank you in advance.
BK
3 hours ago
My issue was that I didn't include in the Request Header the Header name = Content-Type and Value = audio/mpeg. Dumb.
So, for others to get this to work using the HTTP action I used the following settings for our recording which are dual channel:
Request
Method = Get
Request URL = https://api.twilio.com/2010-04-01/Accounts/{accountID}/Recordings/{mediaID}.mp3
Parameter = RequestedChannels: 2
Request Header = Content-Type: audio/mpeg
Response
Response content type: Binary
Encoding: UTF-8
Hope this helps
Tuesday
I'm not sure if the response is the problem. The 400 error is coming from Twilio, not from Workato, so it seems like the URL is bad.
Some thoughts:
Tuesday
Hi gary1. Good to "see" you once again. It is a GET from Twilio https://www.twilio.com/docs/voice/api/recording#mp3 it says..
Appending ".mp3" to the URI returns a binary MP3 audio file with mime-type type "audio/mpeg". For example:
Tuesday - last edited Tuesday
Always happy to help!
I took a look at the documentation and the only thing that sticks out to me is the warning about audio channel availability. Try adding this param to your URL:
?RequestedChannels=1
Like this:
https://api.twilio.com/2010-04-01/Accounts/AC../Recordings/RE...mp3?RequestedChannels=1
Here's a link the warning in the documentation. It reads very much like the issue you're having.
yesterday
gary1,
I used the following since these recordings are dual channel and got the same error message.:
