03-17-2025 06:19 AM
I would like to create a recipe that would perform a one-off initial data load from Workato to Creatio. However I am unsure which trigger is best suited to do just a one-off manual load?
Ideally this would just be something I could run once with the large amount of initial data but so far all I have been using is Webhook Triggers based on various events. The only solution I have seen so far would be to create a scheduled trigger and then delete this recipe after it has run once but I was wondering if there was a more elegant solution for this?
03-17-2025 09:08 AM
Create it as a function recipe. You could then test it (which would actually run it), or you could call it from another recipe.
03-17-2025 05:56 PM
Or create it as an API recipe function and call the API externally to Workato.
