Workato Connector - Developer API
saraiva
Hello community,
In an effort to enhance our CICD pipeline, I was investigating Workato's Developer API (documentation: https://docs.workato.com/en/workato-api.html).
Is there an already made connector to access this API?
I searched in the Community library, but no success. Do you know if it exists? Or do I need to build the connector myself?
Thanks in advance for your time.
Ricardo Saraiva
saraiva
[UPDATE] For the sake of informing other user that bump on this same question...
There's no Workato Developer API connector at the time of writing.
However, as shared by @alain-bates here, there's the connector "CICD for Workato V3" in the community which can be a good starting point. Check it here:
Ricardo Saraiva
8 REPLIES 8
A Workato connector for a Workato API? That would be too easy... 🙃
mppowe
Yea it's a bummer, you'd think there'd be an easier way to access them.  I had to do this a while back too, and it involved making a generic HTTP connector using https://www.workato.com/api/ as the base url and a Header auth with a token, but I think that's deprecated now.  See their doc: https://docs.workato.com/en/workato-api.html#base-url
saraiva
Hello @mppowe !
I'm already building a "Workato Developer API" connector - I don't want to use the generic HTTP connector. I hope I'll release it to the community one day (the API is quite extensive, so it will take some time).
Thanks for your feedback!
Ricardo Saraiva
rajeshjanapati
Hi @saraiva ,
As of now, I guess there is no pre-built connector specifically for accessing Workato's Developer API or for implementing CI/CD pipelines directly. However, you can definitely achieve this by leveraging the Developer APIs that Workato provides.
For example:
  • You can use the Export Manifest API to retrieve recipe package.
  • Then, use the Retrieve Package Download URL API to download the package and store it in your desired location (e.g., a GitHub repo or local folder).
  • For deploying to another environment, the Import Package API can be used along with the appropriate folder ID of the destination environment.
This approach allows you to build a CI/CD pipeline manually and also integrate version control by syncing your recipes with GitHub using GitHub Actions or similar CI tools.
docs url: https://docs.workato.com/en/workato-api/recipe-lifecycle-management.html#export-package-based-on-a-m...
and base URL changes based on your workspace region.
Let me know if you’d like a step-by-step breakdown or need help setting this up.
