07-29-2025 09:27 AM
Hello community,
In an effort to enhance our CICD pipeline, I was investigating Workato's Developer API (documentation: https://docs.workato.com/en/workato-api.html).
Is there an already made connector to access this API?
I searched in the Community library, but no success. Do you know if it exists? Or do I need to build the connector myself?
Thanks in advance for your time.
a month ago - last edited a month ago
[UPDATE] For the sake of informing other user that bump on this same question...
There's no Workato Developer API connector at the time of writing.
However, as shared by @alain-bates here, there's the connector "CICD for Workato V3" in the community which can be a good starting point. Check it here:
07-29-2025 10:28 AM
A Workato connector for a Workato API? That would be too easy... 🙃
a month ago
Yea it's a bummer, you'd think there'd be an easier way to access them. I had to do this a while back too, and it involved making a generic HTTP connector using https://www.workato.com/api/ as the base url and a Header auth with a token, but I think that's deprecated now. See their doc: https://docs.workato.com/en/workato-api.html#base-url
a month ago
Hello @mppowe !
I'm already building a "Workato Developer API" connector - I don't want to use the generic HTTP connector. I hope I'll release it to the community one day (the API is quite extensive, so it will take some time).
Thanks for your feedback!
a month ago
Hi @saraiva ,
As of now, I guess there is no pre-built connector specifically for accessing Workato's Developer API or for implementing CI/CD pipelines directly. However, you can definitely achieve this by leveraging the Developer APIs that Workato provides.
For example:
You can use the Export Manifest API to retrieve recipe package.
Then, use the Retrieve Package Download URL API to download the package and store it in your desired location (e.g., a GitHub repo or local folder).
For deploying to another environment, the Import Package API can be used along with the appropriate folder ID of the destination environment.
This approach allows you to build a CI/CD pipeline manually and also integrate version control by syncing your recipes with GitHub using GitHub Actions or similar CI tools.
docs url: https://docs.workato.com/en/workato-api/recipe-lifecycle-management.html#export-package-based-on-a-m...
and base URL changes based on your workspace region.
Let me know if you’d like a step-by-step breakdown or need help setting this up.
