11-03-2025 04:38 AM
I want to achieve below functionality in Workato without Ruby / Java Script / Python Scripting as scripts are not allowed by our customer .Also JSON Transformations by Workato Action not available in my plan .Without these is there a way to acheive below ?
1) Sort a input json alphabetically ascedending
2) Remove any specific fields from a input json and return updated json
3)Convert any given input json to xml and any given input xml to json
4) Compare 2 json elment structure and return any field mismatch between the 2 json which is present in 1 json not the other json
11-05-2025 03:57 AM
Hi @shivakumara
Yes got it . Since we are making the recipe as an API to sort any incoming json so Parse Json Document Action can not be used in this case . Wanted to know if there are any other action using which we can sort any incoming json without ruby/python/javascript snippets/Json Transformation by Workato ?
