Workato Pros Discussion Board
Forum Posts
Help Us Shape the Workato Community!
Hello Workato Pros! We’re on a mission to make our community forum the best place for you to connect, share, and grow. Your experience matters and we want to hear from you! Take our quick Community Experience Survey below (embedded right in this post...
Resolved! Leveraging Python in Workato > Marketo
Greetings, fairly new to Workato and I am struggling to figure out how to leverage Python to transform data in Marketo.I have a simple script snippet meant to fetch a list of leads whose phone number begins with a '1' and remove it.It works in an IDL...
Printing Outlook email to PDF
I'm trying to help our accounting team be able to easily store and locate evidence of license key delivery emails. Currently they have a giant email inbox which is getting more and more difficult to search for the email copies.I'd like to download a ...
ajorde by Deputy Chef II
  • 5236 Views
  • 10 replies
  • 2 kudos
BIM 360 check if a file exists
We need to copy files from hub 1 to hub 2. there is no issue when a file does not exists in hub 2, but we receive an error when the file exists, which is normal. We tried to create two lists of both hubs, adding an if statement when the file does not...
christin by Deputy Chef I
  • 108 Views
  • 0 replies
  • 0 kudos
Consuming Kafka events using Workato
We are planning to leverage workato to consume events from Kafka generated from our product. Did anyone worked on similar use cases and aware of any limitations or gotchas i need to be knowing before implementing it?
krishna by Deputy Chef I
  • 8057 Views
  • 14 replies
  • 1 kudos
Announcements
Experience Survey
Help us build a space that truly works for you by taking this survey!
🆕 Highlights Hub 🆕
Connect, share insights, and stay updated with the latest spotlights here.
This month’s spotlight: SQL Transformations Connector
Manage Recipe Health with RecipeOps by Workato
Labels
